A50s Software Issue/ battery drain so much
(Topic created on: 03-26-2020 02:05 AM)
rajatpandeyrishi
Beginner Level 3
Tech Talk
a50s software  hang so much after update android 10 , battery was drain so fast, after open 3-4 apps software  start hanging i requesting you please  fix this issue as soon as possible i m very disappoint  after purchasing  4th phone.. not because  i m big fan of samsung its because  software  is user friendly  easy to use & easy to learn new features so please once again i request u fix this
cs_member9
Tech Talk
Dear Samsung Member,
Apologies for the delay in response. However, understanding the criticality of the situation; we had to ensure the well-being and safety of our employees which led to the delay in response.
Hope your issue is resolved. In case the issue still persists please follow the below mentioned steps:
  1. Space availability (Storage & Internal memory): To improve the device performance there should be sufficient space. Request you to keep at least ''minimum 20% internal memory free''.
  2. Clear cache memory of a particular application: Settings>Apps>Select particular app (e.g. Samsung Internet)>Storage>Clear Cache
Battery related Concern: For more information, you can also follow given link:
https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
