Ultra:Battery Drain and Optimization
(Topic created on: 08-06-2024 04:15 AM)
Coffee_Cat
Tech Talk
Galaxy Ultra Battery Life: A Major Disappointment
The Galaxy Ultra is advertised with amazing battery life, but in reality, it's not living up to the hype.
Many users are reporting significant battery drain issues, even with moderate usage. The issue seems to be compounded by high-refresh rate displays, demanding processors, and the constant need to manage power-hungry features like 5G and Bluetooth. While we love the features, it's disheartening to have to constantly monitor battery levels and adjust settings to conserve power. Samsung, we need improved battery optimization and software updates to address this battery drain problem.
9 Comments
goodthings
Tech Talk
SUSANTA3
Tech Talk
Sameer
Tech Talk
Making few changes can enhance battery life to a greater extent ..
Making the following changes as shown in the video ...wait for few weeks for the phone to study the usage patterns and you will see an improvement in battery life
https://youtu.be/DXM7pdW5a-w?si=cXv4W6zVL3JvVBqp
Also make your phone run 2x faster.
https://youtu.be/pgNi1Pmua3c?si=HvJhiGglU77saHG9
Oldy4756
Tech Talk
Well, Dream11 also advertise winning crore's of money but does mostly wins it or losses?
You should see what you need.
It's a big device with 5k mah battery and with oneui heavy skin it won't be sufficient.
You should have gone with other brands.
Coffee_Cat
Tech Talk
On my way to ask samsung that what you know is to be on back of every samsung box 😁
Oldy4756
Tech Talk
Nah. They will go broke, if they do this :)
2Karthik
Tech Talk
I can Give you some tips on this.
● Please don't keep your phone charge till it reach 100%, It may cause Overheat to your Ultra and it ill make more battery problems.
● Please don't Use your phone while charging like Games and Other social media Scrolling.
● Note Down the time of battery consumption after trying these tips.
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links. However, we are taking your valuable feedback regarding this. we are continuously working to make our products better and more efficient.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
