Why Battery Drain Issues Happen in India Region (INS CSC)
(Topic created on: 05-19-2025 11:39 AM)
Startech
Tech Talk
Main Causes of Battery Drain in INS CSC:
1. Pre-installed Bloatware:
The India CSC comes with several pre-installed apps like MyJio, Paytm, Dailyhunt, Moj, MX Player, etc.
These apps often run in the background, consuming data, location, and battery.
2. Push Notifications & Ads:
Some Indian apps and Samsung India features send frequent notifications and ads, which increase background activity and power use.
3. Region-Specific Services Always Running:
Features like Samsung Pay (India), Samsung Finance+, and others keep running in the background, even if you don't use them.
4. Heavier Customization:
The India firmware is more customized with local content and features, which can make the system heavier and less battery-efficient.
5. Slower Optimization:
Because India firmware includes more features, sometimes it takes longer for Samsung to fully optimize power usage after updates.
How to Reduce Battery Drain if Using INS CSC:
1. Uninstall/Disable unnecessary apps like Paytm, Moj, Dailyhunt, etc.
2. Go to Settings > Battery > Background usage limits, and put unused apps to sleep.
3. Use Samsung's Battery & Device Care to monitor power usage.
4. Install Good Guardians (or Galaxy App Booster) from the Galaxy Store.
5. Keep your phone updated – newer software often improves battery life.
10 Comments
NOMAĐ
Tech Talk
India has Good Guardians app??
Royal_RJ
Tech Talk
Even India has no galaxy app booster😂😂😂
NOMAĐ
Tech Talk
Then why this fkr suggesting it??
Royal_RJ
Tech Talk
Just post to show how we are helpless😂😂😂
NOMAĐ
Tech Talk
No one who calls themselves experts, gives practical solutions in this community.
Their solutions are so childish.
Royal_RJ
Tech Talk
True we really need a good and accurate solution
NOMAĐ
Tech Talk
Good guardians app can be downloaded using VPN??
Royal_RJ
Tech Talk
Ok thank you trying
NOMAĐ
Tech Talk
If you do, try using Korean VPN. Do repost back here, so that I'll try as well.
