How to Increase Battery Longevity of galaxy devices : Best practices
(Topic created on: 10-20-2024 01:15 AM)
boywidlens_
Tech Talk
To maximize the lifespan of your your Galaxy devices battery and ensure it performs well over time, it's important to follow some best practices. Here's a detailed guide to help you preserve your phone's battery health:
1. Enable Power Saving Mode
  • This feature reduces background activity, limits CPU performance, and dims the display, all of which help extend battery life.
  • Go to Settings > Battery and Device Care > Battery > Power Saving Mode and toggle it on.
2. Use "Protect Battery" Feature
  • This feature limits the maximum charge to 85%, preventing full charge cycles, which are one of the main factors that degrade battery health over time.
  • Go to Settings > Battery and Device Care > Battery > More Battery Settings > Protect Battery.
3. Avoid Draining the Battery to 0%
  • Lithium-ion batteries degrade faster when frequently drained to 0%. It's best to charge your phone when it drops to around 20%, and ideally, keep the charge level between 20% and 85%.
4. Optimize Charging Habits
  • Avoid keeping your phone plugged in for extended periods, such as overnight. Overcharging can slowly degrade the battery, even with protection features in place.
Disable Fast Charging When Not Necessary
  • Fast charging is convenient but generates heat, which can shorten the battery's lifespan. Use fast charging only when you need a quick top-up.
  • Settings > Battery and Device Care > Battery > More Battery Settings > Disable Fast Charging and Super Fast Charging when you don’t need it.
6. Manage Screen Brightness and Timeout
  • The display is one of the biggest power consumers. Lowering the brightness and reducing screen timeout can significantly improve battery longevity.
  • Use Adaptive Brightness to automatically adjust the brightness level based on your surroundings.
7. Reduce Screen Refresh Rate
  • High refresh rates (120Hz) offer smoother scrolling but consume more power. Lowering it to 60Hz can help save battery.
  • Settings > Display > Motion Smoothness > Set to Standard (60Hz).
8. Turn Off Always-On Display
  • While convenient, the Always-On Display consumes battery throughout the day. Turning it off or setting it to a scheduled time can reduce battery drain.
  • Settings > Lock Screen > Always-On Display > Turn off or schedule.
9. Limit Background App Activity
  • Some apps run in the background and consume battery unnecessarily. Restrict background activity for apps you don’t use frequently.
  • Go to Settings > Battery and Device Care > Battery > Background Usage Limits.
10. Turn Off Unnecessary Features (Wi-Fi, Bluetooth, Location)
  • Wireless features like Wi-Fi, Bluetooth, and GPS can drain the battery if left on when not in use. Turn them off when not needed.
  • You can easily disable them through the Quick Settings panel.
11. Use Dark Mode
  • The Galaxy S23's AMOLED display consumes less power in Dark Mode because black pixels are effectively turned off.
  • Enable Dark Mode in Settings > Display > Dark Mode.
12. Avoid Extreme Temperatures
  • High heat or extreme cold can significantly affect battery performance and longevity. Keep your phone within a comfortable temperature range (16°C to 22°C) whenever possible.
13. Uninstall or Disable Unnecessary Apps
  • Apps that you don't use frequently can still run in the background and drain the battery. Uninstall or disable them to reduce background activity.
  • Settings > Apps > Select the app > Uninstall or Disable.
14. Regularly Update Software
  • Samsung regularly releases software updates that optimize performance and battery efficiency. Make sure to keep your phone updated.
  • Go to Settings > Software Update > Download and Install.
15. Calibrate Your Battery Occasionally
  • Battery calibration can help ensure accurate readings of your battery percentage. Fully discharge your phone to 0% and then charge it uninterrupted to 100% once every 1-2 months.
By following these tips, you can maximize the battery longevity of your Galaxy devices and maintain a healthy battery life over time.
7 Comments
Pavandivvela
Tech Talk
Hmm so disable almost all flagship features after buying flagship device . That's what it seems mostly
boywidlens_
Tech Talk
Just some suggestions, use it as you enjoy 🔥
Pavandivvela
Tech Talk
Can understand ur intention bro but samsung need to control battery drain 😫
boywidlens_
Tech Talk
Yes sir I agree. They say they are working but pata nahi!!
Tech Talk
Nice 👍 informattion
unknown_s
Tech Talk
Thanks For The Information ℹ️
jayasadha
Tech Talk
Your information was very helpful to me. Thank you very much.🙏🙏🙏🙏
