Charging problem..
(Topic created on: 10-26-2024 09:53 PM)
26oct
Tablets
Does anyone knows why is this happening?? Any solution???
7 Comments
CrimsonPeek
Tablets
Bro You got 500wt charging speed on samsung 😂
Aayushh_07
Tablets
Yup😂😂
hiimansh111
Tablets
Restart the device and check
If you like please accept as a solution it's help to others users also
kundankrmahto
Tablets
I don't know why samsung face charging problem most other brands not
Mayur000
Tablets
Battery 🔋 capacity set wrong...
Sometimes overcharge+ using the phone while charging the damage battery capacity data.
You got a mismatched result.
And it's very difficult to find a real technical person who is able to set the correct battery capacity.
Or just replace Battery Controller only
Tablets
cs_member10
Tablets
Dear Samsung Member,
● Clear app cache through Device care:
→ Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
