Resolved! Solved
Charging problem
(Topic created on: 11-18-2025 03:23 PM)
rurock
Tablets
If I connect to charger it show start charging and stop
goodthings
Tablets
Kindly go to service center for check and resolves this issue. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
Tablets
bhghwan
Tablets
Take a brush n colin clean the charging port..with wet brush..don't charge it for 3 to 4 hrs.. after that see charging it will be quite ok..
cs_member10
Tablets
Dear Samsung Member,
● Kindly check connectivity & charger functionality: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Kindly open Device Care from Settings > Battery > Please tap on 3dots (more option) at the top right-hand side > Please select settings> Enable fast cable charging.
● Kindly disable the battery protection mode( if enabled).
● Kindly follow the standard charging procedure. Charge the device in switch-off condition for a minimum of 10 minutes.
● Please check the back panel of your device's physical condition (Bulge, Swelling, or visible damage).
● If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper with the battery also request you to visit the service center immediately.
3. If you do not remember, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
