MAJOR ISSUE: USB default settings MAJOR issue.
(Topic created on: 11-23-2023 04:20 PM)
SataruGojoo
Expert Level 3
Others
I think I have found amajor Issue in Samsung devices, which should be fixeda.s.a.p.
 So, Today... I Connected my phone with my PC usingUSB cable and I come to know that.. as soon as Iunlocked the phone... the phone (My Samsung A34 5G) have givenfull access of Internal Storage to the PC, Which should not be done..This Is Bad, Very very Bad.
i.e. Whenever you connect to PC usingUSB cable the option "Use USB for:" automatically get selected to "Transferring files/Android Auto" bydefault! [Which is avery very bad thing]
 Let's assume, You are in public and your phone's battery is running low and you use thepublic Charging ports available in almost every airports, railway station etc... so as soon as you plug theusb cable and your phone isunlocked..any one(who have access to that usb socket)can access your Phone's internal storage and phone!
 As there is so much DATA FISHING going on.. youcan't be such Guardless in public or Home or anywhere in this Universe.
Solution: I have a solution for this (Not my idea actually. Other phone manufacturers are using this solution in their phones already).
The solution is.. TheDefault Selection should be changed to "Charging phone only
And this can be done by SAMSUNG by providing a minor Software Update to All the devices/Phones.
After that, Whenever you/we will connect our phone to a USB port the Phone willCharge Only, It will not give Access of Internal Storage until you/we give it manually.
Don't compromise with Privacy and Security.
Thank you for reading, Please raise the issue from your end too, If you think I'm right.
9 Comments
DarkClawX
Others
Afai'remember' the 1st time I had connected my S21fe to my laptop it asked me if I wanted to permit the laptop to access the internal data or not.
SataruGojoo
Expert Level 3
Others
So, If you connect your phone with the PC, now... how it behaves?
Does it ask for Permission before giving full Internal Storage access to the PC..or what?
DarkClawX
Others
No, afairemember, it asked only on the 1st time.
Devv_007
Others
Its not a flaw ,it's the way android works.It'll only give the internal storage permission if the phone is unlocked.That's why there are lock options available in it,just lock it and no one will be able to read the files from it,unless someone have your pin.
SataruGojoo
Expert Level 3
Others
Why it's not taking "Charge phone only" as default...! It's safer that way.
arec
Others
Same phone but always it asks for what to do! And it informs usb is connected
SataruGojoo
Expert Level 3
Others
Can't tell bro,
I'm facing this issue all the time.. and the worst part is that.. There is no option to Change the "Default Selection" .
cs_member10
Others
Dear Samsung Member,
We really appreciate you taking the time to share your feedback and appreciate the time and effort you have spent sharing your valuable comments. we request you kindly share the log file. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
SataruGojoo
Expert Level 3
Others
I have send the error report, Successfully.
Please take appropriate actions, A.S.A.P
