Battery drain issue found
(Topic created on: 12-01-2025 08:30 AM)
praveenrajn
Others
5 Comments
cs_member10
Others
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
Ragulk-007
Others
1. Update your software.
2. Reduce screen brightness.
3. Adjust display refresh rate to standard mode.
4. Turn off connectivity.
Disable Wi-Fi, GPS, and Bluetooth when not in use.
5. Turn off AOD.
If you like this solution.
Please
Accept as a solution .
Ragulk-007
Others
1Remove third party apps
or
Put in deep sleeping which apps not in regular usage.
2. Uninstall extra apps
3. Battery optimization.
4. Closed all background applications
Please
praveenrajn
Others
All my other apps are deep sleep or sleep including Instagram. I forcestop which i dont use. Brightness always low, Location turned off, using wifi,.
Removing 3rd party apps😹 what should i use Samsung apps.. 1.30lakh the phone launched. Am turned off almost all features. And you saying unstalling the apps too.. Why i need phone buddy
Ragulk-007
Others
Mee to that problem,
But it adds very little bit sot🫠🥲
