MURSALIN12
03-27-2022 11:35 AM in
Others
BOX SHOULD INCLUDE CHARGER.
CHARGING SPEED IS TOO MUCH LESS NOW.NEED MORE SPEEDY CHARGER LIKE 65 WATT....120WATT.BCZ OTHER BRAND ALREADY REACHED UPTO THIS MUCH SPEED.
I THINK IT'S HIGH TIME TO FOCUS ON CHARGING SPEED.
DO NOT REMOVE CHARGER FROM BOX.NOT GOOD DECISION SPECIALY IN BUDGET RANGE SMARTPHONE.
PLZ WORK ON IT.
BOX MUST INCLUDE THAT MUCH WATTAGE CHARGER WHICH THE SMARTPHONE SUPPORT.
EXAMPLE: DO NOT LIKE THAT
PHONE SUPPORT- 25 WATT
BOX INCLUDE- 15 WATT
DO LIKE THAT
PHONE SUPPORT: 45 WATT
BOX INCLUDE: 45 WATT
HOWEVER NEED MUCH MORE SPEEDY CHARGER.
ANOTHER FEEDBACK
BATERY CAPACITY MINIMUM
5000mAh to 6000 mAh
3 Comments
JatrophaCarcusM 525G
03-27-2022 11:58 AM in
Others
How can u get a 45W or 120W charger under 20k??? Other brands are chinese but Samsung isn't....Yeah I support they should give us charger of 25W under 20K and 45W over 25K...
Sáyân15
03-27-2022 12:34 PM in
Others
Rip your suggestions
Samsung is not gonna follow, whatever you say🤣🤣
04-18-2022 03:06 PM in
OthersDear Samsung Member,
Thank you for sharing your feedback. We welcome your suggestion and appreciate the time and effort you have spent to share your valuable comments. This will help us to improve our services.
