Ev's 🔌 Charging Infrastructure⚡️🔋 Problems🧐 In India 🇮🇳 Problem 📉
(Topic created on: 09-07-2024 09:22 PM)
VrajPatelEditors
Others
Ev Charging Point
1.
In India, major problem is charging points, The charging points are not located in equal distance with each other, and the also, there is less number of charging points available in India. So there is problem for those who are vehicle owners. So this problem must be solved for helping ev owners .
2.
And also if you have any company's car Or Ev's scooter, Then if you charge form any alternate or other company's charger, then there might be damage to the battery due to voltage fluctuations or it might not work, so you might get stucked in middle of the road .
3.
And the third is that if the battery is damaged then the replacement cost or battery in some companies Or car is very very high, so it is not as cheap as it is shows or demonstrated in their commercials or any advertisements .
4.
In the charging points of some companies the cost per charging is also higher. If you have to charge from other alternate company's charging point, this is a major problem too for some owners .
5.
Maintenance Cost Or Relaibility is Too High
Summary :
In short no cost saving is there is Evs As Compared To ICE Vehicles .
Thankyou ,
Vraj Patel
(Editor And Writer)
Disclaimer: Storing This Image In a Retrieval System or Stored in Taping Or Screenshots or Downloading or Photocopying, without the owner's written Permission will be criminal Offence.
Subject To Jurisdiction.
©️2024-2025
VRAJPATELEDITORSINC.
3 Comments
Others
I have a solution. Upgrade to a "Petrol Car". 😉
Others
True 😅
Others
I am always true 😁😉
