Quick battery drain and overheating of S23
(Topic created on: 09-14-2023 07:15 PM)
harrsshh
Others
My samsung S23 (256gb) heats up a lot. Is it the same for others? Or it is only me. While using camera or using the phone outdoors, sometimes, while charging also the phone gets heat up.
My battery also drains very quick. This makes me uncomfortable many times. I am always carrying the charger and the power bank with me because of the battery drain.
Does the heating of my phone and the quick battery drain Co-relate to each other? Is the overheating of my device causing this quick battery drain or, these problems are common with everyone?
My battery life lasts about 10 -12 hours with not heavy use
15 Comments
Others
Devv_007
Others
Yes,heating will drain your battery quickly.
Put it in light mode from settings and download Good guardians>Thermal guardian app (samsung official app) and lower the thermal threshold and enable "Limit CPU boosting when heating" ,this will help to keep cpu temp low and reduce some heating..Screenshot_20230914_191805_Thermal Guardian.jpg
harrsshh
Others
Can't find this app neither in the play store nor in the Samsung store.
And is overheating normal in s23.?
Devv_007
Others
Yep, but after these settings its not.I'll give you the link to download because its not available in India.
CODM6567
Others
One ui 6beta? Or oneui 5.1?
goodthings
Others
My dear turn on power saving mode, turn off location, stop all background apps ,remove unused apps also put unused apps deep sleep or sleep mode, stop adaptive brightness. Thanks.
harrsshh
Others
I am doing exactly the same
And still getting the same issue
Should I visit the service center ?
goodthings
Others
My dear complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report and then go to service center. Thanks.
