Resolved! Solved
how much does charging port replacement cost for galaxy s21 fe 5g
(Topic created on: 06-21-2024 05:26 PM)
sasageyo
My port has become loose and i fear it will stop charging in weeks,hence i wanted to know
Sayan_SS_
Samsung Galaxy S21 fe charging port (type C)- cost amount 2200 rupees as per samsung service center executive...If It is Helpful Please Mark This Comment As Sollution 🙏
2 Comments
Sayan_SS_
cs_member10
Dear Samsung Member,
As per your query, we request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. The repair cost will be confirmed after the physical inspection of the device.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
