rahul36
12-25-2016 09:06 PM in
my galaxy s7 edge battery drain fast. pls tell anyone how to solve the problem
Kanaan
12-28-2016 01:16 AM in
often this quick battery draining doesn't come from the device or the system themselves, check your apps which is consuming a huge amount of battery power from Sitting > battery.
if the problem occurred suddenly, remember which app you have installed recently.
