Battery drain issue
(Topic created on: 04-11-2024 12:13 PM)
das477
Hi, after 6.1 UI update my s23 ultra battery is draining quickly can i know the reason
7 Comments
laibah_59
One of the main reasons is the high display refresh rate (120 Hz), which consumes more battery power. Another reason is the always on display feature, which keeps the screen on even when the phone is not in use. High brightness levels and having cellular data enabled all the time also cause battery drain issues.
Zammi
This is a known issue with the initial 6.1 update. Most of the issues should be fixed with the April update. I would suggest 3 things.
1. Search for Network mode from settings and switch to LTE.
2. Search for Adaptive battery from settings and disable.
3. Perform a factory reset first, then change the above 2 settings. Make sure to back the phone from settings/accounts and backup/backup data.
After reset, the phone will prompt you to restore the backup.
Virk_1
Same here. Bought S23 Ultra bcz of its superb battery reviews and features. But now, since I've upgraded to 6.1. I have to charge my phone twice a day. FYI, I don't play games, I mostly use phone for social media scrolling, and sometimes for photography but the battery is draining quickly. I quickly hope Samsung should fix this issue ASAP
Surazmanee
Same issue
Virk_1
Is there a way to raise this issue to samsung so that they can fix it somehow by updates?
RaptorMM
Same issue, I need to charge the phone 2 times in a day, it just drains quickly
Virk_1
