Battery Drain Issue
(Topic created on: 06-08-2025 10:13 AM)
RobinVarghese
Hey Samsung tech team, my S24 Ultra battery been draining super fast since the One UI 7 update. Can you fix it? Thank U
4 Comments
bishalpaudel1
same here
mohd93
Bro try wipe cache partition hope it will work ...I was too facing the problem but I tried wiping cache partition and my battery backup returns normal
Didionpc
Same issues, but I will try @mohd93's solution after some time.
baselbero
Man thats normal with eveey major softwre update .. it needs time to adapt to the new features and your usage pattern again .. also try to wipe out cache partition in recovery mode
