04-07-2026 08:20 PM in
Galaxy S- Mark as New
04-07-2026 08:39 PM in
04-07-2026 08:43 PM in
04-07-2026 08:56 PM in
04-08-2026 01:39 AM in
04-09-2026 09:39 AM in
Galaxy SThank you for sharing your feedback regarding the battery performance on your Galaxy S25 Ultra. We sincerely apologize for any inconvenience caused.
After a recent software or security update, the device may temporarily experience increased battery consumption while background optimization and app stabilization processes are completed. Battery performance can also be affected by applications running in the background or certain settings being reset after the update.
Kindly try the following steps:
• Restart the device.
• Go to Settings > Battery and device care > Optimize now.
• Check Battery usage to identify apps consuming high power and restrict background usage if needed.
• Ensure all applications and the device software are fully updated via Galaxy Store and Play Store.
• Enable Power saving mode temporarily and monitor performance for a few days.
If the issue continues after several days of normal usage, please contact us through the following link for further assistance:
https://www.samsung.com/ae/support/contact/
