Samsung S24FE battery drain issue
(Topic created on: 04-27-2026 09:03 PM)
best00
Hi friends,
Why my samsung s24fe mobile battery is draining very fast..what's the problem???
4 Comments
celinoo
its the new April update its draining my s24 plus to
best00
What's this samsung???
Samsung_specialist
Thank you for sharing your concern.
Regarding the battery drain issue, please note that increased battery consumption may occur after recent software updates, as the device performs background optimization and adapts to usage patterns.
Kindly follow the steps below to improve battery performance:
  1. Restart your device
  2. Optimize the device from: Settings > Battery and Device Care > Optimize Now
  3. Check battery usage from: Settings > Battery and review apps consuming high power
  4. Ensure all applications are updated via Galaxy Store and Google Play
  5. Reduce background activity for unused apps
  6. Allow a few days for the device to stabilize after the update
  7. If the issue persists, please test the device in Safe Mode to check if any third-party application is affecting performance.
Should the problem continue, we recommend visiting the nearest service center for inspection through the following link:
https://www.samsung.com/ae/support/service-center/
mukti2020
Same issue,
