battery drain fast
(Topic created on: 01-06-2020 06:26 PM)
Not applicable
Hello guys,after i recently upgraded my s10 plus to android 10 i have noticed significantly huge battery issue.it seems i cant even get a 8h in screen display  while my s9+ is doing extremely good (sometimes charge that device once in 48 hours )
Does the android version has to do?
Note:my s10 plus is brand new and is 6 months old
3 Comments
ZayyanBlack
Battery drain is happening with my device from very beginning, but there is way to save your battery. just use medium power saving mode.
www.youtube.com/c/hasinmedia
Allwin11
check battery usage. check which app consume more battery. and force stop it.
Not applicable
i think there is an issue with the android version man
