Battery drain issues
(Topic created on: 02-01-2024 01:03 AM)
arjunajay
Facing too fast battery drain after January security patch update. Does anyone else facing the same issue?
3 Comments
ZUS
Its happening to me as well after updating my S21 FE
Samsung_specialist
Kindly make sure to use an original charger, try to diagnose the battery from the settings > battery and device care > Battery. Otherwise, visit the service center
Rojer30
Just two days I use my new s21 plus facing battery issues while using mobile, battery draining fast . I am using original adapter and cable , please suggest solution
