Water detection problem
(Topic created on: 06-27-2025 11:55 AM)
Goku445
Hi everyone please help me out i update my s23 ultra yesterday after that I am facing water detection problem after 8-9 hours how can i fix that And I didn't even get my phone wet
7 Comments
AvishekG
Many (including mine) Samsung Galaxy S23 Ultra users have reported the “Moisture detected in charging port” error after a software update, even when the phone hasn't been near water. This seems to be a software-related bug, though in rare cases it may be hardware-related.
How to Fix the Moisture Detection Error (Step by Step)
1. Check for Actual Moisture
Just to be sure:
Use a soft, dry cloth to gently wipe the port.
Leave it to air-dry for 30 minutes, or use a cool fan (no heat!).
Do NOT insert cotton swabs or blow hard into the port — it may push moisture/dust in further.
2. Clear USB Settings Cache
A corrupted USB settings cache may trigger this bug.
1. Open Settings > Apps
2. Tap the 3 dots (⋮) and choose Show system apps
3. Search and select USB Settings
4. Tap Storage > Clear Cache and Clear Data
5. Restart your phone
3. Force Stop Android System & Restart
This resets charging and detection functions.
1. Go to Settings > Apps
2. Tap 3 dots > Show system apps
3. Find and tap Android System
4. Tap Force stop
4. Try Safe Mode
To check if the issue is caused by third-party apps:
1. Hold power button > Tap and hold "Power off" > Select Safe Mode
2. In Safe Mode, plug in your charger and see if the message appears.
3. If it doesn’t, a third-party app may be interfering.
cv87
Bro, not able to find system apps in s23 ultra
AvishekG
Steps to View System Apps:
1. Open Settings ⚙️
Swipe down from the top and tap the gear icon.
2. Go to "Apps"
Scroll down and tap on “Apps”.
3. Tap the Filter/Sort icon (3 lines or dots) in the top-right corner.
4. Tap “Show system apps” or “Show system processes”
A pop-up will appear — select “Show system apps”.
If you don’t see that right away, tap "Sort by" > "All apps" or similar first.
5. Now you should see all system apps (like One UI Home, Device Health Services, etc.).
cv87
AvishekG
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Goku445
Actually this problem had happened to me a few months ago as well, and it got fixed in 5–10 minutes. The same thing happened again today
So i want to known that why this is happening
cv87
Got it bro.. thanks..
