07-15-2024 02:46 AM in
Galaxy S- Mark as New
07-16-2024 09:13 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps:
Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
1. Check connectivity: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
2. Check charger functionality: If different devices charge with the same charger. It seems your charger is functioning, before getting into the mobile-related troubleshooting, I would like to know whether you are using a Samsung-approved charger.
Note: We recommend our customers use only Samsung-approved chargers, as 3rd party chargers with different output ratings may cause errors in the device.
If the device charges with a different charger: It seems there is an issue with your charger, kindly check the physical condition of your charger for any damage.
3. Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
4. You can reset your device by following the steps from the below link.
If the issue still occurs, please visit the service center for a physical device inspection. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
07-20-2024 01:06 PM in
Galaxy SHowever, I am currently experiencing an issue with the fast charging feature. Despite connecting the device to a samsung superfast charger, it is charging at a slow speed.
07-20-2024 01:07 PM in
