Charging issue with S25 ultra
(Topic created on: 02-19-2025 09:59 PM)
talktovardhan
facing an issue with my S25 Ultra charging with a original 45w charger and 5A cable. It keeps connecting and disconnecting! Works fine with my S22 Ultra though. Anyone else facing the same problem? #S25Ultra #ChargingIssue
9 Comments
nk023
Facing in s25 plus
talktovardhan
Samsung must address these issues ASAP
cs_member10
Dear Samsung Member,
1.Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
2.Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
3.Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
4.Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
5.If the issue is still not been resolved, Reset the device:
IMPORTANT:
•Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
•Remember google password before resetting the device because it is required during initial setup.
•If you do not remember it, then reset, (Forgot password) your google account.
•For this:
•Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
talktovardhan
Tried everything, but it's still messed up?
DP1010
nope, works fine with my 45w charger and stock cable
talktovardhan
Dont know whether this issue stems from a manufacturing defect or a software bug.
TheRahulS
The supplied cable supports 3A charging whereas the other cables (s22ultra) had cable that supported 5A charging. Samsung has acknowledged this issue of charging problems for the S25 series with the 5A cables and promised to fix it in a n update.
MandeepGujral
Beginner Level 4
Same issue with me
Anuj055
Same issue in my s22 ultra
