07-15-2025 07:52 PM in
Galaxy S- Mark as New
07-15-2025 08:50 PM in
07-15-2025 08:55 PM in
07-16-2025 01:31 PM in
Galaxy SDear Samsung Member,
● Check the charger functionality with a different device or try to charge the same device with a different charger.
Note: Kindly open Device Care from Settings > Battery > Please tap on 3dots (more option) at the top right-hand side > Please select settings> Enable fast cable charging.
● Kindly disable the battery protection mode( if enabled).
● Kindly follow the standard charging procedure. Charge the device in switch-off condition for a minimum of 10 minutes.
● Please check the back panel of your device's physical condition (Bulge, Swelling, or visible damage).
● If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper with the battery also request you to visit the service center immediately.
