Social media upload quality issue in S24 Ultra
(Topic created on: 04-28-2024 08:41 PM)
imRjShah
The most significant issue with photo quality arises when uploading photos to social media platforms. When uploading a photo to WhatsApp status or sending it to someone, approximately 70% of the photo becomes distorted compared to an iPhone, regardless of whether the LN and vita app or another editor is used. While it is understandable that color distortions may occur when adding videos and photos to video editing applications, I did not anticipate such a significant degradation from a reputable company.
9 Comments
007jsr
Right
007jsr
Same problem
owl123
This has been an issue with android for years. If one wants good quality images for social media, then he should go with an iphone
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
arun_23
What resolution have you guys found. I am also facing the same issue and it **bleep**
Lucifeŕ
Hello Robot. Go to Ĥell.
Members_VubL5Rh
Try this. It is time consuming but it works.
For sending to a contact,  go to your gallery, select the picture you wish to send and choose the sharing option, at the top left corner, there are options, click on it and it will take you to, 'automatically convert images and videos' and you turn that on. Go back and then select Whatsapp and send to your chosen contact.
As for uploading on WhatsApp status, go to WhatsApp settings and select storage and data, navigate to media upload and change the quality to HD.
For uploading a Pic or video, you go back to your gallery, and follow the same steps you just did for sending to a contact, and proceed to share it to anyone, it could even be yourself on WhatsApp, then go to your WhatsApp and upload it from there.
It worked for me.
Vidya123
I'm using S24 ultra , I'm not getting HD option when updating the WhatsApp status though I updated the WhatsApp. What might be the issue?
Lucifeŕ
The option he is referring to is under whatsapp settings, not under status settings. However it doesn't help fix the problem. That HD option is only for photos sent over chats.
