12-29-2024 06:34 PM in
Galaxy S- Mark as New
12-29-2024 06:36 PM in
12-29-2024 08:26 PM in
12-30-2024 08:40 AM in
Galaxy SDear Samsung Member,
● Remove the current fingerprint and set up the fingerprint again.
Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
● How to Set up Fingerprint: Path: Settings>Biometrics and Security> Fingerprints> Fingerprint> Scan your fingerprint> Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done> Fingerprint added successfully.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
