Sim No. not showing while incoming call
(Topic created on: 01-31-2024 10:09 PM)
VV
I am using S24+ now. Using dual sim. While incoming call sim number is not showing before the name or number. Previously sim no. is appear while incoming call pop up screen.
13 Comments
GULA851NGH
I am using S24 ultra now. Using dual sim. While incoming call sim number is not showing before the name or number. Previously sim no. It appears while incoming call pop-up screen in my samsung s23 ultra
Kaushik566
S24 ultra does support dual sim dual active?
Ultra23_2023
Is it running latest one ui update? Try rebooting it.
VV
Issue not solved
VV
To fix this
Go to settings/ connections/ SIM Manager/ click on the SIM which logo you want to change and there you can see the icon option. Click on that
cs_member8
Dear Samsung Member,
As per your query, we request you share the log file also share images and a short video clip of the issue for better understanding. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Rajendranick
Only Sim icon not Sim number showing while receiving calls in Dual sim samsung phone after UI update last night. How to reset so that incoming call shows SIM 1 or SIM 2
I have the same issue. Having a sim number was more feasible than having different logo for different sim.
