Incoming call not showing up on lockscreen after update to oneui8 on s24 ultra
(Topic created on: 10-05-2025 01:27 AM)
shal44
Hi,
 After I updated to one ui 8 on s24 ultra whenever I get calls when the phone is locked its not showing up I can hear phone ringing I cant even able to do anything. I literally have to wait till that call to end. But i can able to lift the call when it s unlocked. Does anyone faced this issue.any solution ?
4 Comments
shal44
Cube acr call recorder is the issue after I tried it in safe mode it worked it all because of this app. But why it s not working in one ui8 which restricting the call on the lock screen which is clueless
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
● Check app Cache: Settings> Device care> Storage> Clean now.
● Clear cache memory of a particular application: Settings> Apps> Now pick the app that you like to clear off the cache memory> Storage> Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
