Call screen problem
(Topic created on: 04-25-2025 10:23 PM)
Abubakarrr
On screen incoming calls not showing answer options
5 Comments
Abubakarrr
Arun1405
OMG..
cs_member10
Dear Samsung Member,
● Check app Cache: Settings> Device care> Storage> Clean now.
● Clear cache memory of a particular application: Settings> Apps> Now pick the app that you like to clear off the cache memory> Storage> Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Keep your apps updated: Galaxy Store apps: Open Galaxy Store, tap the Menu (the three horizontal lines), in the upper left corner, and then tap Updates. From here, you can either tap the circling arrow next to individual apps to update one at a time or tap Update All to install all available updates.
Play Store apps: Open the Play Store, tap, and then tap your profile picture. Tap My apps & games. From here, you can either tap Update next to individual apps or tap Update All to install all available updates.
● Kindly restart the device: Press the power and volume down keys simultaneously for a few seconds.
3.If you do not remember password then advise to reset (Forgot password) your Google account.
Abhijeet226
Oh my god, YOU ARE doomed.
Abubakarrr
Ye problem, power saving mode on karne pe aa rahi hai , I hope one ui 7 update ke baad ye fix ho jaiga
