S23 ultra battery not charging and draining so fast after update to one UI7
(Topic created on: Sunday)
PK_31
Facing same issue in S23 ultra after updating latest OS UI7.
My phone is not charging and draining issue. It's very hard to use in day to day as primary phone, also I don't other phone.
Without proper testing and rolled out globally. Worst Samsung experience.
@samsung check this and fix it asap
9 Comments
afeefak7025
Every s23 series user s are facing the battery drain issue problem and heating problem after the update
Samsung need to fix this problem as soon as possible
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
PK_31
Hey BirdMan, Thanks for the reply.
My major problem is phone not charging even though I'm using the Samsung charger for my S23 Ultra which is just a one year old phone.
Ive cleaned the charging port, used blower to remove any particles or debris inside the port and also im struggling a lot put the charger in specific angle to charge my phone. Usually it says fast charging in 50 min then suddenly it says 1hr 50min etc some times that time says 4hrs. I was shocked to see this and few time it won't charge at all Ive to sit at charging port to monitor the phone whether it's charging or not.
goodthings
goodthings
Your's most welcome to here.
This is why Samsung has taken more time to release one ui 7.
sarfarazahmed
I do certain things it help me
1st clear cache
2nd dial *#9900#
scroll down u will find battery reset tap that
3.install galaxy guardian and galaxy app booster from google chrome coz u wont find in galaxy app store
Run to optimize apps and u will
see some difference
Then restart ur phone
Charge it till100% and then use it
cs_member10
Dear Samsung member,
1. Galaxy device battery not charging issue: 1. Check connectivity & charger functionality:
Please check whether the charger cable and adapter is fixed well.
Remove charging cable and reconnect with mobile phone properly.
Check the charger functionality with a different device or try to charge the same device with a different charger.
Note: We recommend our customers to use only Samsung approved chargers, as 3rd party chargers with different output rating may cause errors in the device.
2. If the device charging with different charger, then kindly check the physical condition of your charger for any damage.
3. Please charge the device in switched off condition for 10 minutes.
For devices with removal battery, kindly remove the back panel of your device and check the physical condition (Bulge, Swelling or visible damage). If the physical condition is not good please do not try to charge or tamper the battery also request you to visit the service center immediately.
2 Galaxy device battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
PK_31
Worst reply ever recieved from the Samsung custome support. All these instructions are already followed and many people are reporting this issue only after updating to One UI 7 but samsung won't acknowledge the issue and in return saying follow these troubleshooting steps. Also my device is just 1 yr old and facing charging issues you're not even care to check the issue..
We're eagerly waiting for a security patch for June release and hopefully these issues will be addressed in that update globally.
Are we joke to you for spending such an hepty amount to purchasing your products.
Apple is far better than Samsung.
