S22 ultra green tint Display problem, out of know were
(Topic created on: 07-16-2024 04:08 PM)
justsahil
Hey, my S22 Ultra screen has a weird green tint whenever the Always on Display is turned on or when I use dark mode. The screen is totally fine, no damage or anything. This issue started right after the latest update. Can you help me out with this, Samsung India
4 Comments
change it to 60hz and see if you have the problem
justsahil
Still has the same problem
then it is the problem of display. you might need to replace it.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
