[S21 fe] Wifi calling won't work on airplane mode
(Topic created on: 02-02-2024 02:07 AM)
Sulaimn
On s21 fe, wifi calling turns off( and fails to turn on) when the phone is in airplane mode and connected to wifi.
This is a feature that's availble in iPhones and other phone. Why is galaxy not supporting this?
5 Comments
S_Kumar73
Yes. it won't work in Samsung. You enabled aeroplane mode to avoid phone calls and then what's the use of enabling wifi calling. No logic.
But still u can't compare Apple with rotten orange 😀
kansipajhar
The logic is that if you are in a low cellular coverage area and you have Wi-Fi, you can save some battery with airplane mode on and Wi-Fi calling enabled.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that this is the concept of the device. However, we are taking your valuable feedback regarding this. We are continuously working to make our products better and more efficient.
Sulaimn
That concept is wrong. Few years back wifi didn't work in airplane mode. Now it does. If wifi is there, it's technically possible to enable wifi calling. Its a feature provided by the carrier.
It seems samsung does not support this feature.
