Network problem in GalaxyS23
(Topic created on: 03-11-2025 04:03 PM)
_raj_ib
Suddenly, on my S23 device, I am facing a serious issue related to 5G. While using 5G, calling is not working. Sometimes, when the phone receives a 5G signal, calling is not working. I tried airplane mode on/off, and I even restarted the phone, but the problem is not solved..
3 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode also optimize your's device also reset call settings also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, kindly visit this mentioned link to resolve your Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Kindly make sure that the VONR option is enable on your device.
Path: Settings > Connection > Mobile Network > VoNR (Voice Over 5G).
In case the issue persists, please take your device to the nearest service center for a physical inspection. You can locate your nearest service center by visiting https://www.samsung.com/in/support/service-center/.
