S23 5G issue after call
(Topic created on: 10-07-2024 08:24 PM)
Navjain86
After taking a call, 5g reverts to 4g, but doesn't revert back to 5g after the call ends. I have to switch on and off airplane mode to get it back. Running OneUI 6.1 Oct 4 version. Also, auto brightness is not very active. needs to be fixed
15 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
Navjain86
doesn't sound like a worthy advice. you're simply asking me to reset everything.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
ARJUNB
Expert Level 3
Welcome to the club
Mayur000
Well, some time happened based on location, tower, number of connections...
Switching Network works smoothly when near tower 🗼 has less number of connections..
Sometimes bad networks also change the behaviour of smart phones.
I have no solution.., 😭
SahilNarang
Do 5g only then it will not switch to 4g during call
Navjain86
there's no option of 5g only
SahilNarang
Download Netmonster app go to phone info option and select nr only
