S21 FE Battery Life with no Settings changed
(Topic created on: 05-30-2023 05:17 PM)
SammyUser0036
S21 FE Battery Consumption Breakdown
120 Hz: On
5G: On
Dark Mode: On (Always)
RAM Plus: Off
Adaptive Battery: On
Auto Brightness: On
Location, NFC, Bluetooth, WiFi, Mobile Data everything on.
Modes & Routines:
1. Power Saving on when battery reaches below 20% (power saving mode has all 5 toggles on)
2. Sleep mode turns on Power saving
3. Another routine is in place, which turns off location & NFC, and turns flight mode on as soon as sleep mode turns on.
4. Using official wallpaper of Galaxy S23 (with live wallpaper on lockscreen)
S23 Wallpaper
With this much battery remaining, with Power Saver on, I can easily pull through the day.
16 Comments
PRASANNA007
this is not possible man 😃
viyat
Mine battery performance after factory reset.
Bluetooth and wifi: on all the time except 11:00 PM to 6 AM
Ram plus :off
Gaming: around 2.5 hrs
5G :on
Adaptive battery:on
SammyUser0036
60 Hz does save a lot of battery, but then it takes away the feel of using a flagship...
BTW brightness was fixed or was set to auto? If it was fixed, then at what level?
viyat
Brightness is on auto mode
Ujjwal9
This one is actually good, I liked the standby battery life here.
Pumpy
SammyUser0036
Well you charged in between...
Pumpy
I charge my phone between 30 to 35 %
