S20+ 4G overheating + battery drain
(Topic created on: 02-28-2020 07:08 PM)
samha0
Beginner Level 5
I just received the S20+ yesterday
The overheating is not acceptable at all and the battery drain like hell
I think i will wait till thay find the updated and decide if i well keep it or no .
Dont know what to do
Do u have the same issue?
9 Comments
TECHCASPER
S20+ required a serious update bro..
TajMuhammad
i facing the same issue in future if they send any update then on if not i will switch back to iphone
Samsung_specialist
Hello there,
Battery percentage may vary according to the usage (internet, call, video playback, etc..). However, if you feel that the device battery drains quickly when no function is used, please send the device to one of the service centres to discover and fix the problem. www.samsung.com/sa/support/servicelocation/.
Thank you
ashermark
yes. im experiencing the same way. tomorrow im going back to the merchant to complaint about my exoerience
a2mansour
I'm also facing the same .. it's really bad experience to use Samsung galaxy after long time I'm using iPhone
ashermark
i visited the samsung store 1 week ago. still battery drains like hell and it still gets hot even tho im just using facebook and ig. esp when im outside. it doent happen to me when im using my previous mobile. s20 series is a waste of money. with 4500mah battery and updated processor. this freaking phone cannot be considered as flagship phone. 😭 i want to return ig. but merchant do not allow me. i need some advise / help.
i should buy ip11 instead. battery life is better compare to this 20series .
ashleyjosh79
Beginner Level 3
I have a Samsung S20+ for around 10 days. I have been facing this overheating issue for a day now. but the battery drain is really crazy. 30 mins of listening to streaming music, drained 10% of battery. any idea if this needs to get replaced?
Ali_Elwasief
if a 📱 overheats it's not norma
Ali_Elwasief
***seriously***
