Siva11
02-16-2017 12:44 PM in
Sometimes we are not receiving the incoming when we enabled the 4G data though the mobile network is showing full signal.
3 Comments
Furious
02-16-2017 12:48 PM in
jio rakhe ho kya ?
Siva11
02-16-2017 12:56 PM in
had problem with jio earlier but now for testing purposes I've disabled the second sim completely ,but still experiencing the same
Samsung_India_
02-17-2017 11:40 AM in
Thanks for being with Samsung and for sharing your.
Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. We would like to suggest you kindly follow the below mention steps to overcome the Issue:-
1) Ensure that network frequency of your device should be selected on Auto-mode.
Menu>Settings> Connections>More Networks> Mobile Networks> Network Mode> Select Auto mode (GSM/WCDMA/LTE).
2) Search for the Network Manually as follows:
Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search.
3) You may check by exchanging the SIM in SIM slots.
4) Insert different SIM card in your mobile and check if the issue is resolved or not.
If still issue persists then we would suggest you to once contact with your service provider.
