S23 FE Dual SIM Issue – Incoming Calls Not Received Randomly
(Topic created on: 05-03-2025 08:31 AM)
Hotair
Hi Members,
I purchased the S23 FE (dual SIM variant) a few months ago and have been facing a persistent issue with call reception. When both SIM slots are occupied, I randomly stop receiving incoming calls on either SIM. Interestingly, this issue is intermittent—sometimes calls come through, but often they don't.
Here's what I’ve observed:
If I make an outgoing call, the issue temporarily resolves, and I can receive incoming calls again for a short period.
When I use only one SIM card (regardless of which tray or SIM it is), the problem does not occur at all.
I’ve visited the service center, and they’ve been quite helpful— but the issue still persists on my device.
Initially, I considered faulty SIM cards as a possible cause. However, both SIMs are relatively new and work perfectly fine in other devices. Moreover, even on the S23 FE, each SIM works flawlessly when used alone.
At this point, I’m forced to use my old phone for one SIM and keep the S23 FE running with just a single SIM.
Has anyone else faced this issue with dual SIMs on the S23 FE? Any advice or solutions would be greatly appreciated.
Thanks in advance!
9 Comments
Tarun23456
No I'm not faced this!!
Hotair
I appreciate your patronage, however, I've encountered significant challenges, and the situation is now frustrating.
Janmajaya123
Samsung users, we need your voice!
You also suffering from any issues that you have? You're not alone!
Like, comment & support this post to make Samsung listen!
Click now: https://r2.community.samsung.com/t5/Galaxy-A/Samsung-s-Response-Isn-t-Enough-Look-What-They-Said/td-...
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode also optimize your's device in device care too also clear catche of all apps manually also reset call settings then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
Hotair
I've tried those things already, bro, but they aren't working for me.
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We have highlighted your concern to the dedicated team for further discussion on the case. They will contact you as soon as possible. You are our valued customer, and we appreciate your patience in this regard. We assure to provide you with the resolution as per the Samsung guidelines.
Hotair
No one is contacting me
