One UI 7 Battery & Now Bar Issue on AOD - S23 Base
(Topic created on: Thursday)
ParvezAhmadd
Beginner Level 4
The battery icon and Now Playing bar shift position inappropriately on the Always On Display (AOD). Upon unlocking the device, they abruptly move back to their usual lock screen position. The Now Playing bar also doesn’t appear centered — it’s often slightly off to the left or right, and the same happens with the battery icon.
This issue has persisted for over two months and creates a very poor user experience when locking and unlocking the device. When can we expect Samsung to fix this?
8 Comments
Kabbya_Singha
As far as i know it's not a bug. They change position to save display from pixel burning. It applies for S23 and older series. From s24 series that doesn't change position.
Kml1609
Yes agreed
SATYA35
Mere me v hai ye A35 me😂
Kml1609
Please report call background issue also
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
