Image issue, battery draining issue
(Topic created on: 05-24-2025 10:56 AM)
Avdeepblue
Beginner Level 3
My samsung galaxy s23 base model, after september security patche update, image quality downgraded, After taking a photo and processing it, the result is very poor.
I showed it to Samsung's authorized service center.But it couldn't be fixed from there.
I am currently using one ui 7.The photo here is also very bad.
4 Comments
mathur25
It's not only for S Series it is the same from for the A series i have A55 I also am also facing same issue
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
pallob_barai
I am facing the same problem with my S23 base variant. After one ui 7 update camera quality and overall performance quality degraded significantly. First of all when I updated to one ui 7 my phone was hitting a lot. Then I went to Samsung service center and they reset the phone and now the problem is resolved. But I have noticed that the photo quality in normal mode is degraded significantly, photo looks over sharpened, more grainy . While I am taking the same frame in pro mode without changing anything(like shutter speed, ISO etc)photos are better than the regular mode. After one ui 7 update the low light photos looks much worse than before. I don't know that these are bugs or they did it intentionally but I am really disappointed that now it is happening with flagship phones.
cs_member10
Dear Samsung Member,
As you have mentioned that you have already visited the service center but your device issue still unresolved, So we request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
