Battery drain issue after one ui 7.0 update
(Topic created on: 05-18-2025 01:52 AM)
sam_user778
Hello samsung support,
My complain to you is that many users are experiencing battery drain issue in samsung S23 and S24 base and ultra models both after one UI 7.0 update.
On behalf of the samsung community I request you to resolve this issue for older samsung S models that received one UI 7.0 update and fix the battery drain issue in the next or upcoming update as soon as possible.
8 Comments
goodthings
goodthings
Your's most welcome to here.
Maaaaiii
My display got green lines. After updation
sam_user778
Go to samsung service centre and complain
bornin_96
Beginner Level 3
after update phone got overheating
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
sam_user778
Thank you for your support and tips😊🙏
