04-17-2024 05:13 PM in
Galaxy SHey guys,
My S23U has been affected with this issue even since updating to OneUI 6.1. I have a routine that turns on battery saving mode every night at 12AM and I turn it off manually when I wake up the next morning. The issue is that, notifications from certain apps like Snapchat, SMS organizer (it might be affecting other apps as well but I noticed these two since I use them regularly) are disabled until I open these apps manually after turning off the battery saving mode. I was hoping that this issue would be fixed post the April security/patch but that isn't the case unfortunately. Has anyone else noticed the same issue? Any help to resolve the issue would be appreciated, apart from resetting or wiping the cache partition xD.
04-18-2024 09:46 AM in
Galaxy SDear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
