Hello,
Sorry for the issue you are facing, but have you tried restarting your phone?
And is the issue you face is only while playing the game? or you face it all the time?
Thank you
even my Samsung s10 plus also has same issue I tried to reset phone and after that also still same please help me to solve this problem
Everyone facing same issue on other apps like call of duty free fire also, please resolve ASAP.
I also face this same problem bro..did you find the solution bro?if yes can i also know the solution
I'm facing the same problem
Did u find any solution??
Mine is slightly different. After rescent update, every time I try to turn on the mic it says try again later or something like that in Pubg in lobby. It does not gets on. In game, the option though gets on, but I can't hear others so that they. communication still unavailable in both ways. It happens both on wired headset provided with the device and wireless bluetooth headsets. Please fix this issue.
Mine also same issue dude, found any solution?????????
Yeah, me too I have the same issues I recently bought Samsung S10 lite and it run PUBG smoothly but my friend cant hear me when I use the mic they said the voice is too small I tought my mic is broken so I tried with Discord and it did very well so I think the mic is okay and I think the PUBG is bugging. but after seeing many S10 users who have the same problem I think this was a bug from Samsung.
I hope Samsung fix it soon as possible
