Gap between display and frame of s20 plus
(Topic created on: 12-21-2020 08:01 PM)
Ajaydev
I bought an s20 plus last month. there are gaps between the display and the frame. And it collects dust, but the main issue is I can see diplay light bleeding through the left and right edges of the display and top left corner. Does anyone have this issue? I expected a premium smartphone to be designed seamlessly but I'm disappointed here. Please let me know of anyone has this issue
Ajaydev
here you can see where the screen protector is, and also you can easily see the dust that it collected.
Anikroyale
Take your phone to a service center, they will fix it properly
Ajaydev
will they repair it?😢if they repair, will I loose water resistance?
Anikroyale
You should not worry about that because they are trained professionals, and they know their work, You will lose nothing.
sidanashubham
its normal mine is also like this
Ajaydev
but I doubt about water resistance because the gap.
sahunaveen
any issue in display and touch like color problem..
Ajaydev
no issues with the display.
absrr2708
no
cs-member13
Expert Level 4
Dear Samsung Member,
We request you, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > ask question) so that we can assist you accordingly.
