Gap between display and frame of s20 plus
(Topic created on: 12-21-2020 08:01 PM)
Ajaydev
I bought an s20 plus last month. there are gaps between the display and the frame. And it collects dust, but the main issue is I can see diplay light bleeding through the left and right edges of the display and top left corner. Does anyone have this issue? I expected a premium smartphone to be designed seamlessly but I'm disappointed here. Please let me know of anyone has this issue
22 Comments
Ajaydev
I had already reported it before posting here but they said they are working on it. But still now I haven't received any response from them.
satyanand7
I bought an s21 last week... there are gaps between the display and the frame.... i ordered replacement then the replaced one also came with the more gaps replay as soon as possible what should i have to doo now
alexd086
I have a new Galaxy S21 with a gap between the display and the frame on the right hand side, you can stick the corner of a piece of paper between the frame and the display. I'm not sure what to do about it, the support guy from Samsung said it's normal to be like that but it does not look normal at all.
