Fingerprints sensor issue Samsung S20 FE
(Topic created on: 04-18-2024 07:29 PM)
Monir07
How to solve?
8 Comments
Utsabsamadder
What is the problem actually?
Monir07
Monir07
Utsabsamadder
Go to device care > scroll down > tap diagnostics > tap phone diagnostics > then tap fingerprint test.
Monir07
Utsabsamadder
Do you already restarted your phone?
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
cs_member10
Dear Samsung Member,
As per your concern, Kindly perform the following steps to resolve your fingerprint issue please visit this link: https://www.samsung.com/uk/support/mobile-devices/my-fingerprint-scanner-isnt-working/
