07-02-2022 06:36 PM (Last edited 07-02-2022 06:36 PM ) in
Galaxy S- Mark as New
07-02-2022 06:44 PM in
07-02-2022 06:46 PM in
07-02-2022 08:37 PM in
07-02-2022 08:53 PM in
07-03-2022 09:41 AM in
07-07-2022 07:30 PM in
07-15-2022 02:31 PM in
Galaxy SDear Samsung Customer,
When you scan your fingerprints on the device, be aware of the following conditions that may affect the feature’s performance:
• The fingerprint recognition sensor recognizes fingerprints. Ensure that the fingerprint recognition sensor is not scratched or damaged by metal objects, such as coins, keys, and necklaces.
• The screen protector supplied with the device may cause the fingerprint recognition sensor to malfunction. Remove the screen protector to improve fingerprint sensitivity.
• Ensure that the fingerprint recognition area and your fingers are clean and dry.
• The device may not recognize fingerprints that are affected by wrinkles or scars.
• The device may not recognize fingerprints from small or thin fingers.
• If you bend your finger or use a fingertip, the device may not recognize your fingerprints. Make sure to cover the entire fingerprint recognition sensor with your finger.
• To improve recognition performance, register fingerprints of the hand used most often to perform tasks on the device.
• In dry environments, static electricity can build up in the device. Avoid using this feature in dry environments or before using the feature, discharge static electricity by touching a metal object.
Note: You should make sure to use the highest central parts of fingerprint or the most curved part of fingerprint when you register or scan fingerprint
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
07-15-2022 04:14 PM in
10-23-2022 01:38 PM in
