Fast Charging Problem
(Topic created on: 05-13-2025 04:12 PM)
Chaiee
Hi, I am using Samsung Original 45W Fast charger to charge my S25 ultra but its connects and disconnects in random interval..Still battery gets fully Charged. But when i disable fast charging option from setting then moble charges without any interruption.
2nd issue is If i disabled AOD option setting then its automatically swiches on.
I have already format the device to factory setting also updated to latest update. Still problem Persist
7 Comments
goodthings
goodthings
Your's most welcome to here.
Samsung_OneUi
Not only 45w charger but you also need 5A type c cable for super fast charging
Chaiee
I am using amp cable as well
Samsung_OneUi
5a cable
Chaiee
Yes 5 amp i am using
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
