07-05-2025 11:10 PM in
Galaxy SAll of a sudden, my S24 has stopped charging on 45W chargers (an official Samsung charger).
These chargers and cables will charge other devices fine, so the problem appears to be with the phone. I've checked and cleaned the charging port and can see no debris when shining a torch in it.
The phone will charge fine with an old generic USB-C charger. It also works well from the USB-C port on a multiplug (so USB-C to USB-C). However, this is not a fast charging port, so it appears the issue is only with fast chargers.
When connected to a fast charger, the phone won't charge at all; it's not simply that fast charging isn't working.
I've cleaned the port, checked for updates, turned fast charging on and off, and reset the phone, but nothing has worked.
07-05-2025 11:32 PM in
Galaxy S- Mark as New
07-05-2025 11:33 PM in
07-05-2025 11:34 PM in
07-06-2025 01:10 PM (Last edited 07-07-2025 10:31 AM ) in
Galaxy SDear Samsung Member,
● We always recommend to use genuine Samsung charger for charging your device.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device. When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
