Edge notifications s23 ultra not working
(Topic created on: 10-11-2024 11:22 AM)
mohan28
Hi team
Edge notifications s23 ultra is not working even good lock is reinstalled
Am I missing anything
The notifications is set to brief but it is not working
8 Comments
mohan28
Can anyone confirm please how can it be resolved??
Uninstall edge lighting plus.
mohan28
Did but for whatsapp it is not working
mohan28
Any other setting or configuration?? Needs to be followed
That I don't know as for me edge lighting is working for WhatsApp. You may reset app preferences and apps notification settings with the application as well as system settings
mohan28
Please don't mind to tell how to reset app preference s
mohan28
Can u give the configuration screenshot for notifications for Edge lighting so I follow the same
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appriopriate issue category> Type your query and send.)
