08-01-2025 06:48 AM in
Galaxy S- Mark as New
08-01-2025 06:51 AM in
08-01-2025 06:56 AM in
08-01-2025 07:00 AM in
08-01-2025 07:40 AM in
08-01-2025 07:43 AM in
Galaxy S1. Restart Phone – First thing. Simple but often works.
2. Turn Off Do Not Disturb
→ Settings > Notifications > Do Not Disturb → Turn Off
3. Check Notification Volume
→ Settings > Sounds and vibration > Volume → Slide Notification to max
4. App Notifications
→ Settings > Notifications > App notifications → Enable for all important apps
5. Disable Adaptive Notifications
→ Settings > Apps > 3-dot menu > Special Access > Adaptive Notifications → Set to None
6. Turn Off Battery Saver / Power Saving Mode
→ Settings > Battery > Power saving → Turn Off
7. Safe Mode Test (to check third-party app issue)
Hold Power + Volume Down → Long press Power off → Tap Safe Mode
Check notifications/sound. If working here, some app is causing issues.
8. Clear Cache Partition
Power off phone
Hold Volume Up + Power → Recovery mode
Select Wipe cache partition → Reboot
9. Update Software
→ Settings > Software update > Download and install.
*Ai Generated
08-01-2025 08:26 AM in
06-15-2026 12:27 AM in
